588,020 active members*
8,896 visitors online*
    Apr 2006
    PC to Anilam 1400 Setup
    We are trying to connect one Anilam 1400 to a single PC (have POWERPAK Xpert on the PC) to transfer programs. I have hooked up a loopback connector and used it on the PC and the Anilam 1400 and it looks like each is working. When we use a DB9 NULL Modem cable between the two we cannot get the data transfer to work. The only pins on the DB9 connector of the Mill are 2,3 and 5. Any ideas would be appreciated.
    NW
    Sep 2005
    8
    I have an Anilam Crusader 2 with RS232.
    First you need to test the RS232 - to make sure it is hooked up and working on the Anilam. This is done by making a DB25 loopback connector with Pins 2-3 and Pins 6-20 connected. Next you would issue the Anilam's RS232 Test procedure: [E-stop In][E-stop Out][Manual][Aux]2740[start]
    This test should return a zero (0) in the read out area. If it returns a 38 or a 39 - you have a board or software problem.
    Next - I didn't need to use a Null Modem - but you may have to depending on whether your PC comm port has pin 2/3 configured as send/receive or what.... Try it without the null modem at first.
    Next you can use Hyperterminal -but an easier to use program is DNCSoftware by http://www.dncSoftware.net
    Configure the ports on Anilam and PC for an initial 2400 baud, 7 bits, 1 (odd Parity), xon/xoff
    Anilam: (Input this as a program and auto/start run it)
    [manual][aux]2768[start]
    [manual][aux]2771[start]
    [manual][aux]2786[start]
    [manual][aux]2791[start]
    PC:
    Set this up via Windows/Control Panel/Hardware/Com Ports (and reboot computer).
    PC DNC Software:
    set to same.
    Try sending a file from the Anilam to the PC:
    [manual][aux]2700[start]
    Make sure your cables are firmly attached to the Anilam console...
    IF this works - downloading from PC to Anilam is a similar process.
    Hope this helps - and - Good luck!
    Joe Comunale
    Aug 2006
    32
    anilam
    Hello Joe,
    would those codes work for an 1100 anilam
    Thanx
    Joe Galarza
    Sep 2005
    8
    Hi Joe,
    I really don't know if they would work or not on the 1100. I would say to try it. Then uses something like HyperTerminal or something to see if it works.
    Good luck!
    Joe
    Aug 2006
    32
    I tried but there is no place to put them in (no aux button)
    thanx
