587,252 active members*
3,301 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > 400 lbs cnc gantry for nema34 6 num
    May 2013
    4
    can i use my nema 34 6num 5 amper for my gantry 400 lbs? (200 kg.) --- my x is 260cm ...i have 1 central ballscrew 25mm passo 5.... a use hiwin 20mm.... sorry formy english :-)=.....thank you soo muchAttachment 247834Attachment 247834.... same images of my project
    Re: 400 lbs cnc gantry for nema34 6 num
    Yes, but it may not be very fast with 5mm pitch screws.
    Why is the gantry so tall?
    May 2013
    4
    thank you very much for the reply ... I thought it was too heavy for my NEMA34 6num 5Amp ...... the bridge is high because I want to make a cnc 5-axis ... I know the difficulties ... but I'll try ... and I'm trying various solutions ...
    May 2013
    4
    I do not care that it is a bit slow .... I would like to do even small jobs .... but I like the idea of ​​having a large area to do great things ... lthough if it takes me a long time to me ... like sculpture and bas relief not use the machine for professional cutting
    Jan 2008
    853
    Quote Originally Posted by enzoforum View Post
    You should think about this carefully. You have to see if the speed that it will deliver is acceptable. If speed isn't an issue at all, then any motor can be geared down enough to move any size of gantry. But life is short, the next project is waiting, and your cutters should move through the material at a certain minimum speed or else they will wear prematurely.
    Put another way : you are building a strong steel frame for rigidity, but if the speed is slow, the forces go down, so you might as well build a lighter machine.
    Paul Rowntree
    Vectric Gadgets, WarpDriver, StandingWave and Topo available at PaulRowntree.weebly.com
  1. Nema34 problem
    By pzr in forum Stepper Motors / Drives
    Last Post: 05-31-2014, 03:14 PM
  2. My CNCRouterParts build - NEMA34
    By cogger in forum DIY CNC Router Table Machines
    Last Post: 03-04-2014, 01:53 AM
  3. Nema34 for bridgeport and cnc-router
    By nokillzone in forum Bridgeport / Hardinge Mills
    Last Post: 03-03-2014, 05:59 AM
  4. What you think about this driver for Nema34
    By eerikkarts in forum Stepper Motors / Drives
    Last Post: 05-16-2007, 12:18 PM
  5. Nema23 Or Nema34
    By FLUTE HEAD in forum Stepper Motors / Drives
    Last Post: 07-22-2004, 09:03 PM
