Hello,
I am in charge of a whitney with a Fanuc 18i-P. I am wanting to add tool offsets so we no longer have to add the dimensions of the die to our g-code. I have tried to use g10 command to add the offset but every time I get a improper gcode error. When the offset/settings key is press only the offset and settings menu are available. No work, macro, tool life, tool registration screen or any other options other than the software operators screen. I called Fanuc and they were puzzled.The tech thought it might be a parameter issue but I could not find a parameter related to this issue. The machine was bought second hand and the punch company has no records of the current controller being installed. I will try g41 but I am worried since we use square dies that the offset will be slightly off.
