Hi, i'm just a newb but when i move my cnc, lets say x-axis, 4'' it shows at 1.33 on the mach 3 program?
is it set in mm? what exactly am i doing wrong?
It doesn't sound like a mm/inch mismatch; that would move the stage 4 mm (.1576"). Try increasing the steps per unit for that axis (in Config/motor tuning) by a factor of 3 (triple whatever number you've got in the box) and see if you're any closer. Remember to click "save axis" before closing the motor tuning dialog.
Andrew Werby
www.computersculpture.com
Wow that was it!! Thank you so much! Now everything make a little more sense. Thanks again Andrew
