Originally Posted by
KGD
I'm considering buying the Mach motion software to run a 3 axis mill but I want to make sure I have the physical connections straight before the purchase.
From reading and watching the tutorial, it appears to me that Mach controls the drive with potentially 3 pins on the parallel port. One 5 volt enabling the drive, one for direction, and one for step. So in order to insure compatibility, I should probe to find a 5 volt constant imput from my old pc control to the drive enabling it and two other inputs that change with step and direction. Is this assumption accurate?
So far, I have found one connection that varies from +5 volts to - 5 volts controlling the jog direction and speed. Should I probe for more inputs to match the pinout connections in the tutorial?
