Hello all,
I have reccently upgraded from V8 to V9.1 and all seemed to be fine until I started posting out to my Heidenhain MPH426M.pst when using the drill functions. I dont drill to much I usually leave that to the guys on the machine but where I need to be sure metal is cleared away before certain mill paths I sometimes use the drill cycles. But what I've found is that the drill depth say for the centre drill -2.5 is then used as the Z safety height for the next drill cycle then that drill depth say -44 would then be used as the safety height for the following cycle and the minus sign is also output so pretty scary for the guys downstairs. The problem must be with the post but what do I change ?
Any help would be most appreciated. Thanks.
Alan.
