I'm not sure if this is the right sub-forum for this question. If no, mods please move to where you think is appropriate.
If the drawing above is in the XY plane this shape could be engraved by using a pointed cutter moving along the X axis and moving down then up in Z to vary the width of the cut.
Is there a program that will generate the gcode needed to engrave in this way? I can generate 3D models or 2D vector art.
