588,457 active members*
5,102 visitors online*
IndustryArena Forum > CAM Software > Vectric > photocarve works
Results 1 to 9 of 9
    Apr 2005
    photocarve works
    my works---photocarve the best !!
    http://www.incisionefoto.it
    Sep 2005
    23
    Red face
    Very nice
    Can you tell me, how exact did you paint the wood? Because I'm having some problems with it. When I try to paint the picture, the paint covers only the natural wood texture, not the picture itself. The result is the same as without painting only in different color.
    Jul 2003
    65
    I found that with my photo carvings, the trick was to seal the entire surface with clear first before applying black paint. Once dry, sand the raised surfaces clean of paint. If you don't seal the surface first, the paint gets into the wood pores and is really hard to remove.
    Sep 2005
    23
    How do you seal the pores? What do you use for sealing?
    Today I tried to carve without sealing, here's the result:
    The wood texture realy worsens the quality if the carving.
    Jul 2003
    65
    You can use just about any clear sealer, as long as it's compatible with the paint you will put over it. My favorite is Minwax Polyacrylic since it is water cleanup and dries fast.
    Sep 2005
    23
    Ok, thank's
    Will try this tomorrow
    Jan 2008
    241
    Wow, Nice work
    I'm marking this group for future reference. Perhaps I can learn some pointes on doing photos on my CNC machine.
    Happy Holidays to all.
    Oct 2007
    11
    Nice Photo carve Work
    Greetings all. I was looking through the photocarve posts and was wondering
    what feeds, speeds, step over,and depth of cut y'all are using.
    I have tried a number of projects in PCarve on a number of materials, and my
    results are no where close to what y'all are acheiving, so I was wondering if I could get some pointers on what is optimum.
    Thanks. Jim
    Sep 2007
    48
    about to buy
    I am about to purchase Photocarve. I have DeskCNC which does good for DXF but am not as impressed with it's engraving from jpgs. Is the software the solution? Or is Photocarve really superior? Any pointers?
    Scoob
