588,208 active members*
4,860 visitors online*
    Apr 2012
    4
    Need a custom machine builder
    We are looking for a X-Y axis machine which will automatically raster.
    It will have an optical sensor near the head of the unit which will read the material directly below the head. If it “sees” a piece of material, then it will signal the head to close a circuit. If there is no material, then it will open the circuit. The material is high contrast, so the optical sensor should not be an issue.
    Accuracy is not really that important because the tolerance is 0.06”. The X-axis can increment 0.100” and the same for the Y-axis.
    The head will weigh around 10 pounds, and it doesn’t need to move that fast. If it moves 0.1 meters per second, that would be plenty fast.
    I think it could be built with something like 80/20 or a similar material. I believe the more difficult part will be writing the code. I am unfamiliar with exactly what language these machines use, although I do have a background in computer programming.
    The bed needs to be 34” x 20”.
    I am located in the USA. I am happy to assemble the machine myself over here, if someone could even provide me with consulting services. Since I don’t really know where to start, any advice is gladly appreciated.
    Thank you.
    Mar 2008
    1762
    Re: Need a custom machine builder
    If you wish, we can discuss your machine specs and if needed I can build it for you. Contact info in signature
    Gary Campbell CNC Technology & Training
    GCnC411 (at) gmail.com www.youtube.com/user/Islaww1/videos
  1. looking for custom machine builder
    By BIMP in forum Want To Buy...Need help!
    Last Post: 05-19-2016, 07:13 PM
  2. Job available: Machine Builder
    By Mr. G in forum Employment Opportunity
    Last Post: 09-23-2015, 07:35 PM
  3. No FollowThrough From CNC Machine Builder
    By notselrach in forum Complaints and Praise Discussions
    Last Post: 12-01-2013, 02:41 PM
  4. Machine Tool Builder Macros??????????
    By Rhemenwa in forum Uncategorised MetalWorking Machines
    Last Post: 04-16-2012, 05:23 PM
