588,136 active members*
5,602 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > macro for serial numbering?
    Aug 2006
    13
    We are trying to figure out how to program a mc 50va to do serial numbers and just count for us. Does any one know how to do this?
    May 2011
    27
    I take it you are looking for an Okuma engraving program that will engrave numbers on your parts. I've modified a lot number program for you that I use on a MC-4020 VMC. Is this what you are looking for? (Remove the TXT from the Letters.SSB program name)
    Attached Files Attached Files
    Aug 2006
    13
    Thanks, for the info. We did get it worked out. The issue we were running into was the Sub Program Retrun function and we had a couple of SSB programs loaded adding to the issue.
    Thanks again for your help.
  1. Fanuc Serial Number Macro
    By TomL21 in forum Parametric Programing
    Last Post: 05-11-2024, 05:54 PM
  2. Tool Numbering, What's Your Method?
    By David Bord in forum Tormach Personal CNC Mill
    Last Post: 03-08-2011, 11:20 PM
  3. quick numbering of parts
    By jarend in forum EdgeCam
    Last Post: 07-30-2010, 12:18 AM
  4. macro to engrave serial numbers
    By nmn in forum Parametric Programing
    Last Post: 05-29-2009, 03:33 AM
  5. line numbering
    By xairflyer in forum G-Code Programing
    Last Post: 05-10-2005, 08:22 PM
