Hey,
The total length of a Windows pathname+filename is limited to 256 characters and Windows will not let you create anything longer than that. This is not an issue people run into often with simple files, but when unzipping files with long descriptive folder names, you can easily hit it. One of the situations where you can hit this limit is when you try to unzip, (extract) the electronic copies of some of our books.
If you see this error there are several solutions:
1) Instead of right clicking on the file to extract it, left click on the file to enter the zip directly. Then look for long folder names and make them shorter. Then close the zip file and extract it again.
2) Extract the files to a shorter path, (for instance, you can extract the files to a USB drive) and then edit the folder names down for length so that they will fit several layers deep in your Documents folder.
SO,I would like to suggest you, try LongPathTool program to resolve this issue. This tool is very helpful to resolve the issue.
Thank you!
