This evening while trying to set up a part. TurboCNC seems to make is own travel distances.
If I go into MDI mode and run simple one line codes it seems to be fine.
If I load a program, the zero all my axis, run a couple of lines, stop program, then send the head back to zero. it goes to the negative side of X right on Y and on the plus side of Z by a .25".
Is there something to do with pulse settings I'm missing. The initial screen from TurboCNC states that I can set up to 24000 plus as a pulse code. I'm set at 2000. There is also a line of text that incates pulse settings above 150 can affect speed.
TIA
Neil
