587,744 active members*
3,731 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Wiring diagram for Gecko g540 and cnc4pc C8 relay
    Feb 2008
    13
    Well, after banging my head and trying to make things difficult, I finally have the relay working with my g540 to control my spindle motor. Guess I just wasn't thinking and after getting a boot from my friend, it's purring like a kitten.
    I've included two diagrams of the wiring using a 5vdc psu or a 48vdc psu.
    Comments, corrections, and suggestion are welcome........
    Much thanks to Marris for the 48vdc wiring suggestion.
    Jeff
    Use at your own risk and don't try this at home
    Attached Thumbnails Attached Thumbnails C8 relay diagram.JPG   C8 relay alternate diagram.JPG
    I think I talked to you on the phone a few days ago. If that was you, I went to the website for your SS relay and explained to you how a 4.7K resistor from your motor power supply to the '+' input of the SS relay and the '-' of the SS relay to the G540 output would make everything work and how you would not need a 5VDC supply.
    Mariss
    Feb 2008
    13
    Marris,
    Your correct about the phone conversation and using the resistor from my 48vdc psu. I just happened to use the 5vdc psu because I had one laying around in my shop. I just posted this diagram for any others, (like myself) to use that need a Diagram for Dummies. I also posted a diagram using the 48vdc psu and resistor.
    I greatly appreciated your help and support and love my g540. I would highly recommend this drive to anyone that asked me about it.... :cheers::cheers:
    Jeff
  1. G540 wiring diagram for dummies? :)
    By bkboggy in forum Gecko Drives
    Last Post: 08-28-2010, 07:45 PM
  2. G540 and cnc4pc C8 relay
    By blackrat in forum Gecko Drives
    Last Post: 04-22-2009, 03:03 PM
  3. TREE 310/325 Relay wiring diagram
    By ken fedirko in forum Tree
    Last Post: 02-10-2008, 05:55 PM
  4. My Gecko Wiring Diagram for 201, 210, 212 Drives
    By CJL5585 in forum Gecko Drives
    Last Post: 11-22-2006, 08:17 PM
  5. Gecko Cnc4pc Wiring Diagram
    By mlaws1172 in forum Waterjet General Topics
    Last Post: 09-15-2005, 12:14 AM
