588,711 active members*
6,465 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Using tapered roller bearings in a mill?
    Apr 2014
    19
    I have a X2 mini mill which I'm currently replacing the spindle on. Since it's already disassembled, I'm looking to upgrade my bearings as well, and am looking at tapered roller bearings as an option.
    For those people running tapered roller bearings, how are you keeping the grease inside the bearing? Since it's a vertical shaft, since the grease naturally going to flow out of the bearing over time? Also, don't tapered roller bearings naturally want to eject their lubrication due to centripetal force? How hard did you find it to correctly preload the bearings?
    Finally, are there difference levels of precision with tapered roller bearings, similar to ABEC with ball bearings?
    Nov 2009
    4415
    Re: Using tapered roller bearings in a mill?
    Why not AC bearings?
    A lazy man does it twice.
    Apr 2014
    19
    No way to seal them. I did find out that SKF makes sealed AC bearings, but they cost $70 each.
  1. Not sure if these tapered roller bearings were really a good idea ....
    By JerryBurks in forum DIY CNC Router Table Machines
    Last Post: 11-01-2011, 08:57 AM
  2. X2 motor stalls after tapered roller bearing conversion.
    By TXFred in forum Benchtop Machines
    Last Post: 10-13-2010, 07:44 PM
  3. Roller Bearings
    By Bruggles in forum DIY CNC Router Table Machines
    Last Post: 07-17-2006, 08:11 AM
  4. Tapered roller bearings preload question
    By sendkeys in forum Uncategorised MetalWorking Machines
    Last Post: 03-14-2006, 09:13 PM
  5. 0-90 or 45-45 for roller bearings
    By Ninjak2k in forum DIY CNC Router Table Machines
    Last Post: 04-05-2005, 01:22 PM
