I would like to thank you all again for viewing this post and for all your replies.
Using the information exchanged here, I managed to load a tool in the spindle and release it in good conditions without breaking anything.
@Henrik
After a day of experiments in my shop, I can confirm you were right all along about everything. As you can see in the picture, there are three air inlets in the back of the spindle, and you can tell them by the quick disconnects.
The one in the center says 7 bar. I applied pressure to it and the draw bar was pushed towards the nose of the spindle allowing the pull stud to enter. I didn't have an air valve so i disconnected the hose form the air compressor. The tool holder was immediately pulled all the way inside. So far, so good.
To all that are concerned about the quality of the spindle:
I turned the spindle on at full speed to see if there is any vibration in the endmill or the tool holder itself. All I can say is that the spindle performs beautifully. I was a bit concerned because I thought that any object in the nose of the spindle that is not perfectly balanced will induce some serious vibrations. The tool holders that I use are all Lyndex, and although they are balanced to 12000 RPM, there was no problem turning them at 18000. NO VIBRATION AT ALL! Using a dial indicator, I found that the runout measured on the tool shank is 2 microns. That's about 0.0001 inch. I'd say it is well within parameters.
Back to the rest of air inlets:
I will disregard the left inlet, that's the one maintaining positive pressure inside the spindle, it says .8 bar, and when I hooked the air to it, I could feel the air exiting somewhere in the nose of the spindle BUT NOT THROUGH THE CONE.
However, the inlet in the right of the picture does something interesting.
I hooked 6 bar of air pressure to it with the tool out of the spindle (simply didn't have two air supplies). I could feel the air exiting through the cone of the spindle. I held a 1/2" bt30 endmill holder WITHOUT the pull stud inside the cone, to see if the air leaks anywhere else beside the spindle cone. The air couldn't have leaked through the cone anymore (I checked if I could blow ait through the tool holder before, and I couldn't). But the air can still leak somewhere in the spindle nose, between the rotating ring and the fixed parts. Also, it leaks somewhere in the back near one exit of the inductioin switch wires. But it does not leak through the left inlet (the one that is for positive air pressure) I couldn't feel anything there. So, it must be a separate chamber. What puzzles me is that allthough this inlet says 6 bar, when I applied pressure to it the leaks that I was talking about are very weak. Only the leak through the spindle cone is stronger. The others, are really, really weak. So, it might be that this inlet is only for keeping the spindle cone clean between tool changes? But if this is the case, why the need for 6 bar of air pressure? To tell you the truth, I still need to check what's happening when I apply pressure to both inlets in the same time. I will do it tomorrow, and let you know. Anyway, if the air will exit the spindle through the cone at 6 bar, there goes my Silentaire air compressor. It will not keep up with the air demand...
@Mike
I could set up a system with one valve that has two exits. I could supply 7bar of pressure to the valve, I could use the 7bar on one exit for the drawbar and on the second exit I could mount a regulator first to reduce the pressure to 6bar and use this air for the low pressure inlet. But in this case the valve will supply air to both inlets at the same time. If it is important to do it in a certain sequence...
Regards, Adrian
![Click image for larger version.
ID: 79455](https://en.industryarena.com/forum/attachment.php?s=2503aee7ad13b40d661110c6bc656745&attachmentid=79455&d=1362544827&thumb=1)
