Hello all.
I've just placed my order for a new IH turnkey and thought I'd share some critical specs that the web-site just didn't answer... My only other experience has been on a home converted, 20 year old Harbor Freight green monster which seems to have gibs made of jello so all this is a little new to me.
Optional equipment:
They now have a 3HP VFD that runs through the gear box. RPM is the same as for the 2HP, but the torque advantage should be obvious. The VFD is supposed to be suitable for rigid tapping. Anyone disagree? I'd be using a floating height tap holder since a TapMatic is a little too pricey and I don't need the speed.
NT 30 taper - I'm hoping to build an ATC eventually so I thought this made sense. Tool holders aren't too pricey from MariTool in BT30 trim... Looks like I'll be starting with a draw bar threaded for the BT30 stud hole until I build a finger or ball style draw bar. Tommy was unsure about BT30 compatibility (only knew about NMTB30), but everything I've read says all 30 taper holders would be compatible. Any thoughts? I've looked all over trying to find a replacement finger grabber from a big CNC that I could adapt, with no success.
Table extensions - Standard travel has been confirmed at 28"X, 11"Y, 22"Z. Extensions bring these up to 31"X, 13"Y, Z unaffected.
Lead time was quoted at 6 weeks minimum. Being an optimist, I'm hoping for 8... Something in the back of my mind say 12...
Two small boys at home and a nasty travel schedule for work means I can't afford to spend too much time out at the shop so this will be going into my garage. Space being at a premium, I elected to make my own stand simply so I can fine tune the height.
Can anyone provide the mounting surface to table top (and bottom) heights? How tall is your machine (from mounting surface) at max Z?
Noise might be an issue with the neighbors as I get most of my work done late at night. I could substantially improve that situation with a full enclosure, but I'd also like to know how loud the thing really is. Are the belt drive conversions considerably quieter?
I'm seriously considering a Glacern 6" premium vise ( www.glacern.com/gpv_615 ). These have ground sides for 90 degree mounting which is great, but the primary mounting method is via two sets of bolts to the table. These are spaced at 5" and I have no reference for the T-slot spacing on the table. Obviously I could use the little dogs, but I'd just like to know in advance if I need to get them on order. Can anyone provide T-slot center-to-center spacing as well as the slot size itself? I'm also a little concerned about the weight of this thing. It's 81lbs on the table. Anyone want to comment on the effect this might have on rapids or acceleration?
I'll appreciate any feedback given and will post the actual delivery date for reference on the forum. Thanks to all who've posted so much invaluable on this site!
Best regards,
Ken
