587,475 active members*
3,710 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > HELP PLEASE.... MILL DOWN! Need help on how to gain access to the Y Lube Fitting
    May 2013
    170
    I'm trying to remove the brass fittings for the Y-Axis to unclog the brass oil reducer fittings, but the access is so tight that it will be impossible to get a open end wrench to turn the fittings.
    I was able to get the z-axis, but the Y-Axis is another story.
    I must be missing a trick or something that will make it easy to access the fitting?
    Or can the bearing slides be slid out somehow by loosing the large allen bolts? ( after the slide has been disconnected from the manifold )
    I would do one slide at a time ( with some support under the table in that corner to prevent sagging )
    One additional question.... I would need to know the proper torque when re-tighening the bolts.
    This is on a 2018 Haas DM-1
    Kent
    Attachment 504634
    May 2013
    170
    Re: HELP PLEASE.... MILL DOWN! Need help on how to gain access to the Y Lube Fitt
    Ended up grinding my open end wrench down to the point that it looked like a tool a dentist uses... but that was the ticket....
    I cut a slot on one end for the 1/8 copper tube to slip through
    I did it without having to do anything with the table & bolts..
  1. Lube meters access?
    By DaOne in forum Haas Lathes
    Last Post: 03-23-2020, 08:12 AM
  2. Ball screw lube fitting
    By GITRDUN in forum Haas Mills
    Last Post: 02-05-2015, 05:33 PM
  3. gain shin cnc vertical mill mainteance manual
    By seiauto in forum Knee Vertical Mills
    Last Post: 10-28-2010, 04:18 PM
  4. Fitting a VFD to a Bridgeport mill
    By zoeper in forum Bridgeport / Hardinge Mills
    Last Post: 12-06-2008, 04:59 PM
  5. Re-fitting a mill
    By gunner312 in forum Benchtop Machines
    Last Post: 07-11-2007, 03:31 PM
