588,201 active members*
4,820 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > A lot of deflection on belt driven CnC, better belts?
    Hey guys, I have a zenbot4896 Cnc router that uses belts as the drive system, well they are very flexible, and I don’t want to tension them anymore then they are because I’ve already broke a shaft off of one motor.
    Are there better, tougher belts that I could replace them with? I eventually play on converting to a rack and pinion setup, in just not there yet.
    Thanks in advance!
    Re: A lot of deflection on belt driven CnC, better belts?
    Yes, there are, but you still need to tension them a LOT, which will lead to more broken shafts. What you need are much larger belts, that likely won't even work without a redesign. I would say something at least 2" wide, although ideally it would be even wider. Belts will always stretch, and the longer they are, the more they stretch.
  1. Belt Driven Z Axis
    By FreeRider in forum Momus Design CNC plans
    Last Post: 05-31-2017, 06:47 AM
  2. New CNC build with belt driven Z
    By n0rth3rnlight in forum DIY CNC Router Table Machines
    Last Post: 04-18-2015, 07:18 PM
  3. direct driven or belt driven
    By jeremy0203 in forum Benchtop Machines
    Last Post: 07-27-2011, 05:23 AM
  4. belt driven CNC
    By jwest in forum DIY CNC Router Table Machines
    Last Post: 11-29-2008, 11:10 PM
  5. Belt driven screw ?
    By tomcat47 in forum Linear and Rotary Motion
    Last Post: 01-29-2007, 05:20 PM
