My first big router table design. I built a MOMUS and then wanted a full size table. I designed this one by looking at several other designs, took 3 weeks from start to finish. It has a cutting area of 95x50 in, 10 in in Z height, 2.2kw (3hp) water cooled spindle, HuangYang VFD, USB Smoothstepper, G540 Gecko Drives, Touch screen control and controlling the whole thing is Mach3. The VFD is controlled using Le royaume d'éole plugin for Mach3 using a rs485 connection adapter to a rs232 port. Works great!!!
This short video is a test g code program. There is a ticking sound you hear that is a bad drive pulley that will be replaced as soon as the new one comes in.
Max rapid 1200 ipm, most I do is 720 ipm. This video is 100 ipm, then 150 ipm and then 720, spindle is 15000 rpm, then 24000 rpm.
CNC Router Table - YouTube
