588,397 active members*
4,669 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Setting up a VF machine with the Swarf Tube directed to the front instead of the side
Results 1 to 14 of 14
    Jan 2008
    282
    Good Morning
    Has anyone ever tried to redirect the swarf exit tube to the front? We are looking at putting another machine in our very small shop and it would be much easier if we could regain some of the width of the machine by doing this. The 20 to 24" that might be gained would make it easier to put this new machine in.
    Thanks in advance
    Lowell
    Mar 2010
    1852
    The screw does not enter the tube far enough to hit anything, but just maintain an up angle to allow the coolant to drain down before the chips come out.
    Mike
    Mar 2010
    1852
    If you are going to put another that close, you better have a lot of room in the back to get the coolant tank out and cleaned!!!!!
    Mike
    Jan 2008
    282
    Mike, Good point on the coolant tank, I do believe that you can still gain space by reorienting the Swarf tub because it blocks a passage way between machines. I have hopes that someone else has done this and can share their experience. I can't be the only tiny shop out there.
    Lowell
    Feb 2010
    1184
    Quote Originally Posted by lkenney View Post
    Lowell
    It depends on if you are talking about clocking the chip chute (Swarf tube) or if you are talking about completely redirecting it like 90 degrees.
    I have seen many people clock the chip chute but never redirect.
    Jan 2008
    282
    I am talking about redirection the swarf tube so that instead of sticking out the side of the machine 30 some inches, it would make a 90 degree turn to the front and open that space between machines or the wall. In my setup it will make a difference in having to shovel the swarf or have the machine barf it out the front into a cart.
    Mar 2010
    1852
    45 deg only, or you will dump the coolant on the floor!
    Mike
    Jan 2008
    282
    Correct 45 degrees approx. from the floor to the tube but turning the Swarf Tube 90 degrees so that it runs parallel with the side of the machine, the swarf cart would sit in front of the front of the machine. I am sure we would have to make a custom elbow from sheet metal to do this.
    Lowell
    Mar 2010
    1852
    Lowell
    Sorry, but it is 45 deg or nothing. If you turn it 90 degrees, it will point straight forward and you will loose your coolant. 90 Degs from vertical is dumping your coolant.
    Mike
    Jan 2008
    282
    Mike, I understand that the swarf tube must be at least 45 degrees in the vertical and I would keep it that way but instead of it pointing straight out the side of the machine, I need to turn it so that the swarf exits to the front of the machine. It would still come out of the enclosure the same way but then it would turn to the front of the machine. Coolant would still drain down as it does now. If we plump the exit tube elbow correctly it should not lose any more coolant than it does now. The whole idea is to make the machine shorter (take less space) when looking at it from the front.
    Lowell
    Mar 2010
    1852
    However you wish to word it. Just don't plump the tube too much or it will look pregnant! :banana:
    mike
    Feb 2010
    1184
    Lowell
    The trick will be getting the elbow you want while keeping the chips moving up in the proper direction without packing into the new tube causing everything to jam.
    Interested to see what you come up with. Be sure to post some pictures and commentary on how it works.
    Good luck.
    Jan 2008
    282
    Quote Originally Posted by haastec View Post
    Good luck.
    It will be a couple of months but thanks to all for the advise.
    Lowell
    Jun 2010
    74
    Seems like it would be pretty easy to just use a 90* mandrel bend. They make thin wall mild or stainless at least up to 6-7". That way the chips would move smoothly. If I still had a VF-2, I'd fab one up for you!
  1. Tube becomes dark from anode side
    By OSLaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-25-2012, 08:54 PM
  2. Accumulation of fog on rear side of front glass of cars
    By Lafaso870 in forum Mechanical Calculations/Engineering Design
    Last Post: 09-08-2012, 04:01 PM
  3. Replies: 13
    Last Post: 07-13-2010, 05:23 PM
  4. machine 4 jaw chuck to make it front mounting..
    By pmurdock in forum MetalWork Discussion
    Last Post: 05-05-2009, 12:56 AM
  5. move card slot to machine front panel
    By krfrea in forum Sharp CNC
    Last Post: 12-22-2008, 04:22 PM
