587,952 active members*
3,676 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > V2XT Y Axis Crash triggers "Limit Overload" message, need help
    Mar 2005
    34
    Hi All,
    Have a problem with a Bridgeport V2XT (1995). Operator was moving table in rapid mode, Y axis and jammed the back of the vise which he had over hanging the table into the column. The hit was hard enough to overload the machine and it shut down.
    I have been able to restart machine and jog the table into a neutral spot. When I leave the jog menu and try to ”home” the machine, I get an error message “Limit overload”.
    We have checked all of the limit switches, though they should not enter into this problem, as the operator never ran table onto any of the limit switches.
    I’m guessing the “limit overload” message is tied to the amount of force that the machine exerted when the operator jammed the vise back into the column.
    Any thoughts on where the problem lies and if there is a way to clear the error? Have tried resetting mill with reset button on back of control enclosure and have powered mill off and back on several times.
    Appreciate any and all input to help me resolve this problem.
    Yours, Jim
    Nov 2004
    3028
    Does not compute!
    At this point I would remove the front cover of the Y axis to expose the belt, I would move the belt/pulley by hand with the machine OFF to see if there is an unusual amount of force necessary or if the force varies with direction.
    George
    Mar 2005
    34
    Hi George,
    One of the reasons the error message and incident do not compute is I did not list the error code I saw in the request for help.
    The correct error message is “Over travel Limit Activated”
    As always appreciate your wisdom and knowledge.
    Jim
  1. "Flip 4th Axis" message during Post Processing
    By kfwittekiend in forum Tormach Personal CNC Mill
    Last Post: 09-30-2012, 04:29 PM
  2. Replies: 0
    Last Post: 11-25-2011, 12:32 AM
  3. Haas VF2 Z axis crash, now Z is off .027"
    By SC300DRIFTER in forum Haas Mills
    Last Post: 11-07-2011, 03:48 PM
  4. "Test this axis/Run", and a limit switch
    By greybeard in forum LinuxCNC (formerly EMC2)
    Last Post: 01-31-2010, 12:08 PM
  5. V2XT error message "DRIVE FAULT detected (0,z,y,x) check log"
    By rfdoyle in forum Bridgeport / Hardinge Mills
    Last Post: 10-08-2007, 09:35 PM
