588,348 active members*
5,528 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 3M Manual Pu;se Generator incorrect, parameter?
Results 1 to 9 of 9
    Oct 2012
    33
    Hey Guys,
    Brought back to life an old Kitamura Mycenter1 with the Fanuc 3M control. Everything appears to be in working condition except when I jog the axis, the control reads greater than what the actual movement is. Example, I have a total of 16" of travel in my Z, yet when I handwheel the Z axis manually, the control says I come up close to 31", so I know it's off somewhere.
    I was looking at parameters 007, 008, 009 and was able to get close to an actual movement number but still not correct.
    Anyone ever experienced this before and have any helpful tips I can try to do? Thanks!
    Matt
    Aug 2007
    795
    Re: Fanuc 3M Manual Pu;se Generator incorrect, parameter?
    what about CMR DMR settings?
    let us know ball screw pitch and number of encoder pulses
    Oct 2012
    33
    Attachment 347100
    Here's the servo on the Z axis, trying to see what the pulses are with this servo. I'd like to guess that it's 2000 since "2000M" is stamped on the tag. The other number is "M-412132"
    I'll keep digging...
    Aug 2007
    795
    what is in parameters 17 and 30 and what is ballscrew pitch?
    Oct 2012
    33
    Parameters:
    17: 01010101
    18: 01010101
    19: 01010101
    17, 18, and 19 should respectively be X, Y, and Z
    30: 8000
    31: 8000
    32: 8000
    Kitamura has no info as to what the ballscrew pitch could be in that machine.....
    Feb 2013
    151
    Matt,
    That 2000M on your motor is the part number for the motor itself... You need to take the cap off the top of the motor and look at the info on the encoder itself. You probably do have a 2000 count encoder, but they did make a 2500 count unit as well.
    cj
    Oct 2012
    33
    Ah I got it figured out, silly mistake. When I was inputting the parameters, I changed the parameter to have the machine read in Imperial instead of Metric. I changed that back and everything is well again. Thanks for all the suggestions!
    Dec 2009
    977
    Quote Originally Posted by mnmattie View Post
    imperial instead of INCH ????
    Aug 2007
    795
    I'm not sure, but to my mind coordinate grid may be in metric, while Fanuc will display moving in INCH on the CRT and vise versa
    there are different parameters for displaying and counting
  1. Fanuc O-T parameter manual
    By Rocksalt in forum Fanuc
    Last Post: 04-04-2024, 03:35 AM
  2. Need Fanuc OT Parameter manual
    By Jwl in forum Fanuc
    Last Post: 12-20-2019, 12:42 PM
  3. Replies: 0
    Last Post: 05-14-2015, 11:12 AM
  4. I want to get about FANUC OL CNC parameter manual
    By michael lee in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-11-2014, 10:17 AM
  5. Fanuc Parameter Manual
    By Garto in forum Fanuc
    Last Post: 06-23-2007, 04:31 AM
