I bought a new DB25 cable with male connectors at both ends, to connect the computer (Mach3) to a CNC4PC breakout board. For 2 days I have been trying to test the most elementary arraignments, with no luck.
Finally, I tested the pinouts of the 2 male connectors. There is no logical correlation between the two. The pin sequences are not the same, they are not reversed and in fact some pins do not even transmit a signal to any of the pins in the other connector.
Could someone please explain what I bought and what the problem is?
Thanks.
