Re: "R less than z in cycle in xy plane" and I have no clue
I went back and re-did the part in BobCAD as I suspected it might have something to do with inexperience since this was one of the first parts I experimented with but never actually cut. This time it seems to work, I haven't cut yet but I ran in a local simulation copy of Mach and it didn't balk. Unfortunately, I don't have the old version so I think I'll just move on and call it "experience".
I did run into an odd thing though - the 1/2" hole on the left edge of the part is roughed as a pocket with a finish profile pass. I used the Spiral option for material entry with the default .25" radius. Even with simulation I did not notice that the roughing was actually cutting a much larger pocket offset from the center. So I ended up with a much larger hole that is offset. I would have expected BobCAM to report that the cut was going outside the boundary. Now I know to pay close attention to these things.
I use this hole as my datum and probe to find its center. I have a couple of options to fix this. I'm leaning towards milling a larger .9" hole offset so the incorrect hole is completely removed. The only reason I need to do this is because the finish pass took a little crescent out of the right side of the pocket so it is not perfectly round along X. In practice this should not cause a problem since I could still probe the middle and all of the hold down locations will be bored after probing. But I'm a bit of a perfectionist so I think I'll overbore the hole and adjust my part offset by .1" (which is what I determined by measuring) and go from there.
Reelsmith, Angling Historian, and Author of "The Reelsmith's Primer"
www.EclecticAngler.com | www.ReelLinesPress.com
