588,225 active members*
5,121 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Edgecam code wizard problem
    Jan 2010
    20
    Hello everyone, I am having trouble compiling a Code Wizard Document (.cgd) to a Compiled Code Generator (.mcp)
    I open a template in the code wizard fill in my parameters, save as Code Wizard Document (.cgd), but when I try to compile it the code wizard crashes.
    Am I doing something wrong??
    Hope someone can help me
    Best
    Colin
    Jun 2008
    125
    Hi Colin,
    Is this only happening when you start a new template? Can you open an existing CGD and compile it, or open one of the example posts and compile that?
    I have seen issues with pc's with poor graphic cards crash when using code wizard, but if you can open existing posts then it would eliminate this.
    What template is it, is it mill or lathe? I think there might have been an issue with certain lathe posts a couple of releases ago where it wouldn't compile out of the box, but that came back with a warning which you could fix.
    Feb 2008
    Re: Edgecam code wizard problem
    Hi Dahlberg. Did you find out how to fix it?
    I am having the same trouble.
    Best
    Pappasmier
  1. Edgecam 2010R2 Code wizard
    By Carbmax in forum EdgeCam
    Last Post: 10-05-2011, 10:26 AM
  2. NEED HELP WITH CODE WIZARD
    By modulus in forum EdgeCam
    Last Post: 03-24-2011, 01:05 AM
  3. Edgecam Code Wizard help needed
    By mbbert in forum EdgeCam
    Last Post: 12-18-2010, 02:53 PM
  4. Write Wizard Code Generation Problem
    By saabaero in forum Tormach Personal CNC Mill
    Last Post: 10-30-2008, 10:34 AM
  5. Edgecam Code Wizard
    By KSTDIJA in forum Uncategorised CAM Discussion
    Last Post: 07-01-2005, 11:48 AM
