588,225 active members*
4,516 visitors online*
Results 1 to 6 of 6
    Aug 2005
    12
    New Taig, 8 ipm maximum rapid speed?
    I just got my Taig setup, I am using Flashcut and I cannot get over 8ipm. If I go any faster the motor will freeze and it will say the computer can't communicate with the Flashcut box.
    I've messed around with the feedrate and ramping settings and that's the best I can get. I am wondering if it could have to do with the stepper motors? The ones I have are supposed to be 166 oz, I don't know for sure though it looks like they had labels on them that were ripped off. There was one that is bigger and I put it on the Z axis, however it doesn't go any faster.
    Would I get faster rapids if I went to a different/stronger stepper motor? Could it have something to do with Flashcut?
    www.fivaxis.com/cnc2.jpg
    Mar 2005
    159
    For what it's worth.
    I use a Xylotex board and his 270oz steppers on my Taig and I get around 40ipm rapids.
    Bigger steppers are not the answer. In fact somewhere there is a thread pointing out that the best speed was obtained using 127oz steppers. (I believe that was the size).
    Can you run Mach3 with your interface board? Worth a try if you can.
    Aug 2005
    12
    Ok I'm starting to think its a computer/communication problem. I'm using a laptop with a serial port, I'm going to try it on my desktop to see if it works.
    Aug 2005
    12
    I tried it on the desktop, same exact thing. I guess I will try Mach3.
    edit- Well I can't figure out the first thing about Mach3.
    Nov 2003
    126
    The controller has no idea if the motor is spinning or not. The motor stopping with an error is the result of a problem elsewhere...
    Since the software reports an error, the problem is with with the cnc controller hardware, software, or computer. I would contact Flashcut, since it is their controller and software.
    Mach3 is not compatible with that system.
    Mar 2005
    159
    It seems as if you are narrowing down to the problem.
    I wanted to post the article I read showing the different speeds vs stepper torque.
    /quote
    By Tony Jeffree:
    I did a very interesting test the other day on my Taig mill.
    I bought one of the original Taigs with 140 oz-in motors, rated at
    1A/phase
    (something like 7 volts to drive that through the 7 Ohm coil
    resistance) -
    it was the first of their mills to be imported to the UK a few years
    back.
    A couple of years later I upgraded to their current 200 oz-in motors -
    still 1A/phase, so even higher coil resistance - ~9 Ohm IIRC. I
    recently
    decided to give the mill a makeover, firstly to improve on the drive
    coupling and bearing end-float adjustment arrangements (which can be
    surprisingly bad on the standard mill - my worst axis had about 5 thou
    backlash), and secondly to convert from Taig's old "bi-level chopper"
    drive to
    a modern microstepping drive. Having re-vamped the mechanical side to
    the
    point where I can no longer measure any backlash, I decided to see what
    maximum step rate I could achieve with three alternative motors, using
    a
    driver capable of unipolar half-stepping at up to 2A/phase and a 24V
    supply
    (actually one of my Divisionmaster units).
    The first motor was one of Taig's "standard" 200 oz-in 1A/phase motors.
    The
    max half-step rate with this motor before losing steps was 1250
    half-steps/sec, equating to around 9.4 IPM (20 TPI leadscrews).
    The second was a 254 oz-in, 2.5A/phase, so with the reduced (2A) drive,
    effectively a 211 oz-in motor, so very comparable to the first in
    holding
    torque. This managed 4000 half-steps/sec or 30 IPM.
    The third was a 140 oz-in, 3A/phase motor; again, with the reduced
    drive,
    effectively down-rated to 93 oz-in. This managed 7000 half-steps/sec,
    or
    52.5 IPM.
    The differences here are basically down to differences in motor
    inductance;
    the higher the inductance, the worse the high speed performance will be
    for
    a given supply voltage. So, given unlimited driver voltage, these
    differences would not be a problem. However, in the real world, where
    drivers suitable for a machine like the Taig (e.g., the Xylotex board)
    are
    often limited to a supply of around 30-40 volts, choosing a motor that
    has
    lower torque and low inductance is often a better deal than choosing
    one
    that has high torque but higher inductance.
    Needless to say, I will be using the 140 oz-in 3A/phase motors for the
    final
    configuration, but will be driving them at their rated 3A/phase and
    will be
    using a ~40V supply and a microstepping drive. If you do the math on
    what a
    motor like that can deliver through a 20 TPI leadscrew, you reach the
    conclusion that this combo can quite happily generate a force of around
    100-140 Kilos at the tool tip (factoring in leadscrew efficiency and
    the
    dynamic torque the motor can generate). I feel that should be more than
    sufficient for a mill the size of the Taig, and certainly, the ability
    to
    do rapids at >50IPM is way more than I will ever need (or will feel is
    safe!) on this machine.
    /quote
    James
