588,202 active members*
4,620 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Possible G0704 high speed spindle motor,
Results 1 to 7 of 7
    May 2011
    308
    Possibly this could work as a high speed spindle motor on a G0704.
    300W spinlde motor and 52mm spindle fixture/ spindle motor/ DC motor-in DC Motor from Machinery on Aliexpress.com
    At 52 mm it could fit inside the quill if one wanted with an adaptor. Otherwise one could hang it on the side with the included bracket.
    May 2011
    308
    Here is another spindle motor but this one says 57mm diameter. Will still fit in the 60 mm quill and run off the stock grizzly speed controller. This will get you up to 8000 rpm with an ER11 chuck.
    Use this motor for small cutters, switch back to the stock motor /spindle for hogging steel.
    Technical parameters
    Baby details of technical parameters
    Can be used for carving metal or non-metal materials
    Radial runout of about 0.01-0.03:
    Working voltage: 12-110VDC
    Power: 300W
    Speed:110VDC3000-8000r/min
    Torque:4000 g / cm
    Insulation resistance: >2me
    Dielectric strength:400V
    Diameter:57mm
    The chuck portion length: 40mm
    Chuck diameter : 16MM
    Chuck: ER11 chuck with 3.175sandwich
    Motor total length:220mm
    Spindle weight:1.6 kg
    The tail with a cooling fan
    Aliexpress.com : Buy Free shipping! CNC engraving machine spindle 300W from Reliable Spindle suppliers on Stepper motor Asian resources
    I don't understand where the wires run though.... Through the fan blades?
    May 2011
    308
    This 2 axis setup is kinda cool. Looks like it includes driver boards as well. I'm confused by the size and weight though. The connector in the photo is probably 1" long but the shipping dimensions are 7.87in x 3.94in x 3.94in.
    Packaging Details
    Unit Type:
    piece
    Package Weight:
    5.0kg (11.023lb.)
    Package Size:
    20cm x 10cm x 10cm (7.87in x 3.94in x 3.94in)
    Aliexpress.com : Buy Free shipping! CNC engraving machine stepper motor driver board rotation axis A axis B axis fourth axis and fifth axis from Reliable Axis of rotation suppliers on Stepper motor Asian resources
    Aug 2010
    630
    Quote Originally Posted by Turbo442 View Post
    Power: 300W
    Torque:4000 g / cm
    Diameter:57mm
    Installing inside the Quill? Would be kinda hard to switch back and forth. I would prefer a secondary spindle mount and leave the existing stuff alone. Not to mention if you've done a ATC and Power Draw bar...
    Inner Vision Development Corp. - http://www.ivdc.com
    Website Design & Development. Shopping Carts, SEO and more!
    May 2011
    308
    My stock spindle slides out with by loosening one screw. Takes 20 seconds. But hanging it off the side works just as well too.
    Aug 2010
    630
    My stock quill slides out with by loosening one screw. Takes 20 seconds. But hanging it off the side works just as well too.
    Photos of how yours is setup?
    May 2011
    308
    Here is my setup. Baldor 1hp, 3 phase, 2 pole motor , on 2 hp vfd. Spindle bearings and grease upgraded. Motor mocked up at the moment, seeing if I can use the gearbox still. I think most of the noise on this machine comes from the spindle rattling around in the splines. I think I am going to machine in a plastic spacer that slides in between the spindle shaft and splines. Like the one Hoss printed recently.
  1. Where to buy high speed spindle/motor for wood cnc Singapore region?
    By Calico in forum Want To Buy...Need help!
    Last Post: 05-01-2012, 03:22 PM
  2. High Speed Spindle for G0704 for Alu and Brass
    By hive8 in forum Benchtop Machines
    Last Post: 04-29-2012, 04:14 PM
  3. G0704 Fluctuating spindle speed
    By prcdslnc13 in forum Benchtop Machines
    Last Post: 04-23-2012, 11:11 AM
  4. Low and high speed spindle motor
    By cncor in forum Uncategorised MetalWorking Machines
    Last Post: 09-04-2008, 04:23 AM
  5. High Speed Spindle for Taig - Brushless Motor?
    By GammaWill in forum Taig Mills / Lathes
    Last Post: 03-29-2007, 09:43 AM
