588,657 active members*
5,709 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Need help with M05. spindle does not stop
    Jan 2009
    34
    We have recently purchased a demo SKT210SY. I need help with a few things first. When a M05 command is issued is the spindle supposed to stop or coast to a stop. If there is a command i need to make the spindle stop please let me know.
    Jesse
    Sep 2011
    15
    First of all, make sure your control is looking at the correct spindle encoder. M54 is the code for that. We had the same problem and traced it down to coolant leaking out of the spindle and getting on the belts and brake disc. Our machine dealer retrofitted the spindle with o-rings and solved the problem.
    Jan 2009
    34
    Wow, talk about a delayed reaction. This post is almost 3 years old. But you were correct the belts were loose and oily causing them to slip. Thanks for the reply though.
    Apr 2008
    10
    Hi Jesse,
    Would you mind elaborating on the repair? I am having a similar problem with an SKT21-LMS. M5 does not stop spindle and AL-15 SPINDLE COMMAND TIME OVER during a run.
    Joseph
    Jan 2009
    34
    Joseph,
    My problem was actually very simple. The belts on the main spindle were loose and very greasy. So what was actually happening to me was that the motor its self would stop with the mo5 but slick loose belts allowed the spindle to remain spinning when the machine thought it had stopped. When m05 was given and the motor had stopped it would release again and allow the spindle to simply coast to a stop.
    hope that helps..
  1. e stop and spindle (on/off)
    By Zygoat in forum LinuxCNC (formerly EMC2)
    Last Post: 03-10-2010, 04:43 AM
  2. spindle won't stop
    By HBFixedGear in forum Fadal
    Last Post: 07-07-2009, 10:30 PM
  3. How can I stop the spindle ?
    By tmead in forum Mach Wizards, Macros, & Addons
    Last Post: 04-01-2009, 04:50 AM
  4. spindle start/stop through VFD
    By endgrainguy in forum CNC Machine Related Electronics
    Last Post: 01-09-2009, 04:47 PM
  5. VMC-15: Spindle Would Not Stop !
    By StormWerkz in forum Fadal
    Last Post: 04-25-2007, 05:30 PM
