588,510 active members*
5,087 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > tool blocks for 2000 and 2500 sy
Results 1 to 7 of 7
    Nov 2007
    188
    Any body now a good place to buy new or used tool blocks for doosan lathe other than doosan theres are real high
    Oct 2009
    118
    2932
    Sep 2006
    57
    I second the MD tooling suggestion
    They have very innovative static holders (quad turning holders, and a great cutoff blade holder)
    Their live tools are less expensive than the Daewoo standard (at least used to be standard) Eppingers. But, the Eppingers are more rigid. We use the MD's for drilling / reaming work, but always use Eppingers for milling applications (they handle side load much better)
    Aug 2004
    218
    Don't even consider these guys, I payed for 3 pcs. of BMT 55 live tools an never recieved them. A $1980.00 mistake.
    http://www.vdi-tools.com/front/bin/home.phtml
    2932
    Quote Originally Posted by chucker View Post
    No, they're not cheap from Doosan. But they work, they fit, and they're quite often in stock. And, as Mroy0404 has discovered, cheap can sometimes be VERY expensive.
    Feb 2003
    349
    when you buy a machine, order double the Tools, then they are not expensive.
  1. tnc 2500 M90
    By kennyayr in forum Bridgeport / Hardinge Mills
    Last Post: 01-30-2010, 02:50 PM
  2. 2500 sy
    By STS_Kevin in forum Daewoo/Doosan
    Last Post: 01-28-2010, 02:46 AM
  3. Need Help finding tool blocks !
    By pyroshizzness in forum Mori Seiki lathes
    Last Post: 03-13-2009, 05:04 AM
  4. Puma 400 Tool Blocks
    By TURNER in forum Daewoo/Doosan
    Last Post: 03-07-2009, 10:15 PM
  5. Help Tnc 2500
    By opa3279 in forum Bridgeport / Hardinge Mills
    Last Post: 02-24-2008, 05:09 PM
