Hello Every one. I have machine Machmaker with Control Haindenhain 155Q. I am facing a problem that the machine does not move in one direction like if it is woking well in Y+ then it will not move in and Y- at the same time same case with X axis but Z axis is always good. Then I press emergency stop and start the machine again then both sides will work well for one time only ( Like if I move the machine in y- first then it will move there as many time as it will try but if I press y+ then It will stop y-) same is the case with x axis. If I press manual data input mode or any other the control stops responding unless I press Emergency Stop. Please help
