BobCAD CAM V24 Standard / BobART
File Import:
CAD – Legacy BobCAD-CAM
DXF – AutoCAD
DWG – AutoCAD
STEP,STP – Step
IGES,IGS – Iges
SAT – ACIS
3DM – Rhino
X_T – Parasolids
X_B – Parasolids
SLDPRT – SolidWorks
BBCD – BobCAD-CAM
STL – Stereo Lithography
File Export:
IGES, IGS – Iges
DXF – AutoCAD
DWG – AutoCAD
SAT – ACIS
3DM – Rhino
STP,STEP – Step
BBCD – BobCAD
Surface Creation & Tools:
Planar
Skin
Revolve
Offset
3 Edge
4 Edge
Cross Section
Extrude Curve
Extrude Surface
Multi-Sided Patch
Fillet
Extend Surface
Intersection Curves
Un-Trim Surface
Break Surface
Sweep
Solid Creation & Editing:
Sphere
Cube
Cone
Cylinder
Torus
Fillet
Add, Subtract and Intersect Booleans
CAM Features:
Wizard Driven CAM
Tool Database
Speed & Feed Calculator
Save & Load Tool Path Setting
Associative CAM
Tool Path Simulation
CAM Tool Paths:
2.5 Axis Drilling
2.5 Axis Profiling
2.5 Axis Pocketing
2.5 Axis Facing
2.5 Axis Chamfer
2.5 Axis Threading
2.5 & 3 Axis Engraving
2D & 3 Axis Plunge Roughing
3D Slice Planer
3D Slice Spiral
3D Engraving
3D Slice Radial
3D Z-Level Roughing
3D Z-Level Finishing
4 Axis Indexing
4 Axis Wrapping
BobART:
Import – .BMP, JPEG, PNG, EPS, AI, PDF
Photo Embossing,Turn Pictures directly into 3D Relief/Embossed models
Raster to Vector Conversion
Embossing & Debossing
Emboss from dxf files or solid shapes
Texturing
Mirroring
Lettering
V Carving
2-Rail Sweep
Sculpting
Smoothing
Material/Texture Selection
Al DePoalo
Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
