588,215 active members*
4,165 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > 8 mm or 3/8" shank straddle knurls??
    Aug 2007
    105
    hey all, I was wondering if anyone knew where to get a straddle style holder for my swiss machine, but in an 8mm shank. everything i've found is 12 or above. I talked to genevieve swiss to see if it'd be possible to grind down one of their 1/2" holders, but it's not possible.
    anyone know of anywhere else??
    thanks!!
    Feb 2008
    267
    You could...
    If this is for a gang tools position, you could drill and tap a 12MM holder and bolt an 8MM adapter ... that you would have to make.
    If this is a turret position, you could mill out the holder pocket to accept the 12MM shank.
    Good luck!
    Feb 2008
    586
    Call AccuTrak. They should be able to help you, adapt a holder for your needs.
  1. 1/2 Shank End Mill
    By duhtrev in forum CNC Tooling
    Last Post: 08-04-2008, 09:27 PM
  2. Drawing a threaded shank
    By wdp67 in forum BobCad-Cam
    Last Post: 10-18-2007, 02:16 AM
  3. Tapmatic shank change
    By ozzie34231 in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 04-25-2007, 06:52 PM
  4. Tapered shank drills sharpened
    By Rockwell in forum Hobby Discussion
    Last Post: 04-19-2007, 02:44 AM
  5. Flycutter shank style
    By thackman in forum Benchtop Machines
    Last Post: 03-07-2007, 06:41 AM
