587,547 active members*
3,173 visitors online*
Results 1 to 8 of 8
    Dec 2010
    Sven's modified Momus build thread
    Hey, everyone, I am currently finishing up my first year of Mechatronics Engineering at the University of Waterloo in Canada. Our class has decided to host a design symposium in approximately 5 months so that everyone can show off there projects that they were working on during their co-op terms ( Waterloo Engineering students switch between school and co-op every term to get a good grasp of real engineering practices, this also leaves us with lots of free time, due to having a void of homework and studying).
    I have decided to embark on designing and building a CNC router.
    My main goals are:
    - Keep it fairly cheap ~ $1500 initial investment including a router
    - Ability to machine 1/4" aluminum and polycarbonate (I am also a mentor for a FIRST robotics team and I hope to accurately machine gearbox plates from plate aluminum)
    - A cutting surface of 12" X 24"
    - A small enclosed design so that I can keep it in my basement
    - A good portion designed by myself / an old design modified to meet my needs
    I started off buying the Momus design, because it appeared to fit my needs the most. I read through the plans and looked at ways I could modify it to meet the rest of my goals. This meant to remove most of the gantry and design it a bit more rigidly using a Joe's hybrid approach of aluminum extrusion, V bearings and angle iron. I also decided to use lead screws instead of the belts due to the increased accuracy for aluminum.
    As this is my first CNC build / design, I am looking for help and advice regarding the design. I included 3 pictures of the rough design that I have so far. So if you see any issues or anything I can improve on, or if you have any questions about my design decisions please let me know
    So far I have purchased
    $20 - Momus Plans
    $105 - 200 oz-in steppers (They are fairly weak but I am hoping to use them for now and in the future upgrade the one on my Y axis and put two of these on my X axis)
    $25 - computer with parallel port
    Well I hope this will be my first of many posts as I should be starting with the base as soon as my exams are over. Once I have free time I will also be asking more specific questions as right now I should be studying for my calc and statics exams
    Oct 2004
    590
    Your modifications look good. I like the use of the Vee bearings on all axes and switching to threaded rod should give you better drive stiffness over timing belts for milling aluminum. Using Vee bearings greatly reduces component count and should improve the ease and possibly the accuracy of initial adjustment. I can't tell if your rails are square edge aluminum angle or true vee profile. If they're aluminum they can be 'conditioned' into a vee rail. For more on this process see page 14 of Chapter 1 in KRMX01 pdf.
    Chris
    Dec 2010
    Chris, the idea is to plain steel angle and to make a more pronounced V using an angle grinder.
    I currently have 3 200 oz-in stepper motors (KL23H276-30-8A) I purchased these thinking they were 282 oz-in (which they are when wired in bipolar) Unfortunately I was planning on using them with a hobby CNC driver.
    Are there any low cost bipolar drivers on the market? Or should I purchase a stronger 300 oz-in motor for the Y axis, and put two of the 200 oz-in guys on the X axis, Or will I be fine using just the current steppers?
    Sven
    Oct 2004
    590
    Quote Originally Posted by svenw View Post
    Sven
    Are you saying that those steppers are weak because you've actually tested them and tried to stop the shaft from turning or are you imagining they're weak because they don't match up with the general trend of what you see people using?
    In my opinion the best bipolar drives available in the DIY CNC world are Gecko's. If you're serious about staying involved with DIY CNC then they're a very good investment...but they do cost more than many others that are available.
    Chris
    Jul 2011
    16
    You should be fine using those motors with the hobbycnc driver... I am using 127 oz. in motors with the same board on my machine for all 3 axis and they seem to be holding up to the task... They are what I had on hand and I wanted to test them before purchasing new ones... When I build my v2 machine, I will go with larger motors, but if I were you, I would go with what you have...
    Dec 2010
    Chris
    Yes, I am worried about them being too weak because of the general trend of what people have been using. And although the gecko drive are most likely the best bi-polar drives out there, they are unfortunately too far out of my budget. Instead I am looking for something around the cost of the Hobby CNC, if not I will most likely be going with the Hobby Pro kit.
    I think I will be staying with what I have, worst case scenario I will have everything together and realize they are too weak and just buy some larger ones.
    Since I finally finished school for the summer I had some free time at home. I found a great torodial transformer which I pulled out of a 15 amp Farm charger. I measured the various voltage possibilities which varied from ~8 to 14 VAC.
    Since there appear to be 6 separate loops in the secondary windings, would I be able to run half of them in series, creating essentially 3 loops twice as long? If my understanding is correct this should double my voltage giving me a possibility of 16-28 VAC which will be perfect for a Hobby CNC power supply.
    I also started and finished the main box. I asked a good friend of mine who does some awesome cabinetry and some unique furniture if he would be willing to help me out. We started yesterday morning and picked up 2 sheets of maple veneer plywood. 16 hours later we had cut, glued, sanded, and finished a solid base for the router.
    This project is turning out to be a perfect experience and I already have so many design improvements which I need to put into solidworks
    If anyone knows their way around transformers I would love to have some advice about how to modify the torodial I found.
    Let me know what you guys think so far, and and stay tuned I will most likely be starting with the electronics and Gantry in the next 2 weeks.
    -Sven
    Attached Thumbnails Attached Thumbnails 20120822_112407.jpg   20120822_114839.jpg   20120822_114848.jpg   20120822_135839.jpg
    20120822_160823.jpg   20120822_182824.jpg   20120822_183637.jpg   20120822_234711.jpg
    Aug 2006
    132
    Nice work!
    You have access to an excellent commercial table saw and the results of your woodworking reflect carefull cutting and planning. Very good!
    Regarding your transformer... confirm that the pairs of output windings are not connected to other pairs and if so, they *probably* can be 'added' to achieve the voltage you are looking for. Rectification and regulation will follow unless your driver board(s) and electronics can receive AC input.
    I suspect it is too much to ask if you happened upon a schematic of the farm charger while salvaging the transformer?? It may be possible that the wiring pairs are maked.. perhaps one with a 'dot'. This would indicate which wire has a phasing relationship with the input mains AC.
    Also check other builds using toroids for similar situations. Someone is certain to have tried/done this before.
    Again, nice work!
    -=Doug
    "IT ≠ IQ " Starwalt 1999
    Mar 2008
    11
    Wink Momus Design
    I currently have access to a wood cutting cnc and would like to know if anyone has put the pdf files for cutting into vecters. just to maybe let me look adjust and maybe save some time. Would be helpful and id apreciate it.
  1. 404's Momus V2.0 build
    By e404_forbidden in forum Momus Design CNC plans
    Last Post: 09-22-2013, 02:49 PM
  2. starting my momus 2.0 build
    By Friction_Burn in forum Momus Design CNC plans
    Last Post: 09-18-2012, 05:35 PM
  3. Second Momus Build (Pro Version)
    By bjesson in forum Momus Design CNC plans
    Last Post: 07-14-2012, 12:21 AM
  4. My Momus build
    By TeslaFreakshow in forum Momus Design CNC plans
    Last Post: 12-06-2011, 11:35 PM
  5. Modified 3.5"-5 O.D. Buttress Thread
    By nitemare in forum MetalWork Discussion
    Last Post: 01-17-2008, 07:51 PM
