I need to mill a pocket that is going to be very deep ~4.5" in aluminum. It will have one wall that is that deep and the other walls will be ~2.5" so chip clearance shouldn't be an issue. I have the tormach modular insert cutter which may be close but I am thinking maybe a shear hog and then a long 1" endmill for finish. There are no sharp interior corners so I could use something bigger if need be. Do you think I should just plunge rough then use the big shear hog? Any thoughts would be appreciated.
I had a problem with the modular cutter but I have a feeling it was because the tram was off a bunch when I tested it. Going to test it again this weekend.
-Keith
