![Quote](images/misc/quote_icon.png)
Originally Posted by
ger21
Are you talking about the issue with the spindle starting during power up?
It's not really a bug.
The UC300ETH pin states are different than the ESS, so when you use a breakout board designed for the ESS, you run into this issue.
I was originally using an MB2 breakout board, designed for the ESS. When I switched to a UB-1 breakout board, designed for the UC300ETH, I no longer had this issue.
And as was mentioned in that thread, you shouldn't have power to your machine until UCCNC is running.
