588,410 active members*
5,126 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Corner rounding on 1 edge of solid cube
    Apr 2003
    14
    Hello group,
    Using V20, how would you get just one edge of a solids cube to have a corner radius? I see the filleting command that does all the outer edges, but how do you just add a fillet along one edge. Also, when you have a solid model done and only want to machine certain areas, do you have to create a boundry and use that option in the toolpath generation? The general methodology of using BobCAD has me stumped.
    Pat
    Apr 2003
    14
    Well, I found out that if you select the solid first, filleting will be done all around the part. If you have nothing selected, then it asks for the edges to be filleted. No exactly a consistent process.
    Pat
    Jun 2003
    446
    Pat,
    Do you have the V20 training videos?
    CNC Dude
    Apr 2003
    14
    CNC Dude,
    No, I don't the training videos. I am too cheap. I started using V18 for a small mold project and haven't used Bobcad much in the last year.
    Pat
  1. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
  2. corner rounding
    By inthedark in forum Uncategorised MetalWorking Machines
    Last Post: 02-08-2004, 01:30 AM
