Hello,
I'm considering building a machine to make "talking strips". These are essentially linear records, with a series of bumps on a long, thin strip of plastic. You drag your fingernail over the bumps to play it.
A movie of my test strip is below and a picture is attached. It's a bit hard to hear, the message is "Kiss me you fool".
http://glassgiant.com/talking_strips/talking_strip.mov
The stip is about 3/32 of an inch wide by 1/32" thick by less than 2 feet long. The bumps are very, very shallow: they appear to have been stamped. You can just barely see them in the attached jpg.
I was wondering if anyone has any general tips for how to constuct a machine to make these on a "one-off" scale? The one I have was manufactured in bulk. My background is programming. I have a growing workshop in the basement. Mostly my hobby work is with wood, but I have a retired shop teacher for a father-in-law who is pretty good with metal. I have a bit of experience with electronics and making pcbs.
My initial thought was to source similar plastic strips somewhere, have it on a spool, then feed it over a small platform then to a pair of rollers to grab it, take out any slack, and measure the distance. Over the platform I had planned on having a router that would take away all but the ridges. Seeing an actual talking strip now, though, I think the ridges are too close together. Maybe a solenoid to stamp each groove individually? I thought I'd take the audio from wav files and convert it to the series of bumps. There are several C packages out there that deal with audio. I may even be able to use Flash, though I'm not sure. Now I'm wondering if I'm complicating this too much.
Does anyone have any general tips for doing something like this?
