588,399 active members*
4,908 visitors online*
Results 1 to 6 of 6
    Feb 2010
    1184
    Fanuc 31i RS232 Help
    I have a Robodrill Alpha T14e with a 31i control that I cannot get RS232 set up correctly.
    As far as I can tell, I have this control set up exactly as my Robdrill Mate running an Oi control that works just fine. I am using the same RS232 cable to eliminate potential errors.
    Using channel 0 for RS232 In/Out
    Baud Rate set at 11 for 9600
    Stop Bits at 2
    Parity is Even
    The communications software is set up to reflect the above information and like I said, my other Robo works just fine.
    Is there another parameter or setting that I am missing? Perhaps something different or extra from the Oi and 31i control?
    I should also mention that this machine was recently purchased used and it lost the SRAM right of the bat because of a weak backup battery. The SRAM was reloaded by the local dealer but the communications did not get tested before the tech left.
    Any suggestions? Any other details I need to provide?
    Feb 2010
    1184
    Nothing?
    24220
    I am not sure what ports you have on the 31i but is the I/O channel set for the correct post?
    Al.
    Albert E.
    2932
    Are you getting an alarm? Bad data? Nothing?
    As Al said, check that the port is correct for I/O channel = 0. I had this happen recently on a 31i. I was getting a 086 alarm, even though a good cable was plugged in to the DB25.
    Feb 2010
    1184
    Well, I come in today and try to load a program for giggles and it works. I am not quite sure what or if I have done anything different that before other than I had an operator loading a program like he did with the older Oi control. I was probably doing it similarly to the Oi also, but I am thinking that I may be on a different screen today than I was before when sending my request to load.
    Soooo, aparently my problem is operator error.(chair)
    Fanuc controllers are not my strongsuit, see screenname, but I am slowly getting them figured out.
    Thanks for the replies.:cheers:
    24220
    Quote Originally Posted by haastec View Post
    Our powers here are pretty extensive.
    (Miracles take a little longer)!
    Al.
    Albert E.
  1. Using RS232 on a fanuc 10m
    By davidrvalencia in forum Fanuc
    Last Post: 05-20-2021, 07:24 PM
  2. Fanuc 11M RS232
    By 9566317 in forum Fanuc
    Last Post: 09-24-2015, 10:02 AM
  3. Fanuc 10T RS232
    By TheGreenMachine in forum Fanuc
    Last Post: 08-14-2013, 02:40 PM
  4. fanuc 0t rs232
    By rvila in forum Fanuc
    Last Post: 04-02-2010, 06:02 PM
  5. Fanuc 31i-A , RS232, DNC
    By padobranac in forum Fanuc
    Last Post: 01-25-2009, 04:52 PM
