587,941 active members*
3,138 visitors online*
    Jun 2003
    167
    Need some help choosing laser engraver
    Hello,
    I am looking to get into doing laser engraving and maybe some cutting. The cutting if done is not a high priority and would be just on thin stuff. I am not new to CNC. I have built 4 cnc routers and a cnc foam cutter. I want to mainly engrave on bone, deer antler, tortoise shell, wood maybe some soft stone. I need to be able to do small work, the largest piece I am interested in engraving would be 8x10 inch or smaller and I need to be able to engrave legibly in a nickel size circle. I have a small budget of less than $1000.00 to get this started and be able to do work with it.
    Here's my question; given what I have described above can this be done? Do you have any machine recommendations? I am not afraid of used machines. I am now running two cnc routers, could one of them be fitted with a laser head? What problems are lurking out there I have not considered? What software is good and bad?
    Thanks for any help or suggestions. Ron
    Feb 2012
    387
    Re: Need some help choosing laser engraver
    Ron,
    for the laser machine ,if below USD1000, should be the K40 on ebay , others then the used one maybe
    A normal machine price should be around USD2000
    Quote Originally Posted by foamcutter View Post
    Hello,
    Lucy Lee G.WEIKE LASER
    [email protected]
  1. Hot!!!! Dissount now----Economical Co2 laser engraver/ cnc laser cutting machines
    By Lasersolution in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-13-2014, 06:00 PM
  2. Hot!!!! Dissount nowEconomical Co2 laser engraver/ cnc laser cutting machines
    Last Post: 11-13-2014, 05:57 PM
  3. wklaser (Gweike laser) 2011 No. 1 Hot Product--6040N laser engraver display
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-05-2014, 02:25 PM
  4. Replies: 0
    Last Post: 07-05-2013, 08:44 AM
  5. CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!!
    By oliver9866 in forum Engraving Machines
    Last Post: 12-15-2010, 09:44 PM
