Hello All,
Apologies for jumping straight here with a problem thread. I've been reading for some time but never required to post until now.
I have attached a photo of my tube with the lights in the room off so you can see better (though it's not a good pic!).
At the back connector for the tube you can see a pink/purple glow where it appears there is an arc from the cable.
Basically the machine ran fine with no problems at all on last use. I fired it up yesterday and it wouldn't cut through. The beam looked focuses on the material just not going all the way through. So I whacked up the power to see and heard a crackling arcing sound.
I then took off my extension box (a box that fixes on as I upgraded tube and it sticks out). And there is some evidence inside that of arcing to the frame, despite the connector being heavily siliconed and a rubber sleeve over it. So I thought it was losing power to the frame.
Tried it without the box and could see this arcing through my silicone so removed that to see.
Any ideas?
Cheers
Rich
