588,504 active members*
4,744 visitors online*
IndustryArena Forum > CAM Software > Mastercam > canned lathe cycles
    Mar 2004
    60
    canned lathe cycles
    i'm using the okuma post for the osp 7000 updated fron ver 9 to x
    when i try and post a thread op (longhand or canned) it puts the start of file info at the end. does anyone no what would cause this. the post worked right out of the box except for this and some other minor changes.
    N100 X4.35 Z.2359
    N110 G71 X4.0966 Z-1.65 A30 H.1534 D.024 U0. F.125 M32 M75
    $MACHINE_GROUP_1.MIN%
    NAT01
    ( TOOL - 1 OFFSET - 1 )
    ( THREAD O.D. INSERT - TOP NOTCH THREADER )
    N120 G0 G40 X20. Z10.
    N130 G97 T0101 S150 M41 M4 M8
    N140 G0 X4.35 Z.2359
    N150 M9 G97 S800
    N160 G0 X20. Z10. T0100
    N170 M05 M02
    I remember someting about fastmode on will cause canned cycles to do strange output sometimes. To check go to settings, machine definition manager, when in here at the top there is an icon that will say control def. open that in the area look for nc output in here look for post debug information and a box that says enable. make sure this is off no check mark if it is not on I would have to see the post. sometime it may be missing a $ somewhere.
    Hope this helps
    Steve
    www.cad2cam.net
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Mar 2004
    60
    steve that did not seem to work
    Pete,
    Send me your Post I can take a quick look.
    www.cad2cam.net
    www.cad2cam.net
  1. Anilam Crusader M canned cycles
    By scottmi in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-08-2009, 06:39 PM
  2. Help w/ Fanuc 6T Canned Cycles!
    By andys2006 in forum G-Code Programing
    Last Post: 04-17-2007, 03:15 AM
  3. G90/G91 in canned cycles
    By alfalfa in forum CamSoft Products
    Last Post: 02-25-2007, 12:20 PM
  4. canned cycles on Haas
    By GITRDUN in forum Haas Mills
    Last Post: 09-21-2006, 01:58 PM
  5. Incremental Canned Cycles?
    By Rekd in forum Haas Mills
    Last Post: 11-15-2003, 07:23 AM
