588,169 active members*
4,421 visitors online*
    Jan 2012
    13
    Slowing Down my A-axis
    Okay gurus,
    I need to run my A-axis at a much slower rotation speed. My ez-cam is spitting out an F460.824 speed for A-axis while I'm running xy @3 ipm and z at @.1 imp. As it seems I cannot control the A-speed in the cam software.
    If I change the radius, higher-i get a higher speed of 600. If I place .0001 or leave it at zero in my settings, I cannot get it under 460.824.
    Whats' the best way to lower my rotational speed? I seem to want mach3 to overwrite the A speed.
    I don't really want to lower using the FRO as this will lower the xyz accordingly.
    Any help is appreciated.
    Thanks.
    ecad
    It has to be a CAM setting. the only thing you can really do in Mach3 is lower the A axis velocity to give it a maximum, but that's not really a good option.
    Feb 2007
    664
    Try inverse time , if ez-cam has it
    Jan 2012
    13
    I came across the velocity setting in mach3 and lowered the velocity to 400 from 600. I was skeptical whether this changed the amount of rotation but a quick test in air does not change the amount of rotation. I went from 0 to 90 okay. The FRO shows 464 and actual speed at 400 which is the speed I put in mach3. I might need to lower it more say 200 as I use lowered sized bits.
    I will test cutting something quick to verify.
    Why would it not be good to change this setting?
    I can't figure out what is controlling my A speed in the cam software. There is no box for me to enter speed other than xy and z. I'm using the indexing command to cut circumferential grooves that go from 0 to 120 degrees.
    Jan 2012
    13
    Quote Originally Posted by holbieone View Post
    I'll check on that but it does not sound familiar in ez-cam.
  1. Slowing a spindle down
    By Fred Ming in forum DIY CNC Router Table Machines
    Last Post: 11-25-2009, 06:58 PM
  2. Slowing down the graghics simulation
    By dfrey2@rocheste in forum Haas Lathes
    Last Post: 08-04-2008, 02:03 PM
  3. Slowing a motor
    By dighsx in forum CNC Machine Related Electronics
    Last Post: 02-24-2006, 12:44 PM
  4. Slowing down feed
    By xairflyer in forum Mini Lathe
    Last Post: 04-27-2005, 07:42 AM
  5. Forum posting slowing down?
    By samualt in forum Community Club House
    Last Post: 09-27-2004, 02:14 PM
