588,499 active members*
5,325 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 0i TF, Manual guide i Problem with engraving od of a part
Results 1 to 6 of 6
    Sep 2005
    281
    Hello, I am using the engraving part of EZguide this is a puma 2600y2 I am engraving around the diameter of a part ZC (G07.1), I got it to work but cant figure out why it wants to move to a minus Z and then plus Z and then do the engraving? I have to cheat the tool Geometery offset to get it where I want it to be? is this a parameter setting? or am I missing something? thanks
    Sep 2005
    281
    Sep 2005
    281
    Re: Fanuc 0i TF, Manual guide i Problem with engraving od of a part
    Sorry, didn't mean to post this twice
    Sep 2005
    281
    Apr 2018
    138
    I consolidated your multiple threads into this one. Multiple threads in different subforums can lead to a mess once a member replies. If there are multiple threads, it gets confusing when a member knows he posted a reply, and yet doesn't see that reply. So duplicate threads are not permitted.
    Yes, I understand, that a thread perhaps could be in any of several subforums, but the solution is not to create more threads. Instead, I suggest adding more details to this thread. The more info you provide, the more likely that someone may recognize your situation and post a reply.
    Sep 2005
    281
    Thank You
  1. Oi TD Manual Guide i Text Engraving.
    By Dave1200 in forum Fanuc
    Last Post: 10-26-2018, 06:24 PM
  2. Fanuc Manual Guide 0i (CAP)
    By vincent.pomerleau in forum Fanuc
    Last Post: 08-16-2015, 03:29 PM
  3. Fanuc manual guide
    By Chip in forum Other Manufacturing Processes
    Last Post: 10-03-2010, 01:48 PM
  4. Fanuc 18i-TB with Manual Guide i problem
    By mroy0404 in forum Fanuc
    Last Post: 03-21-2010, 06:47 PM
  5. FANUC 18i with Manual Guide
    By Jays in forum Fanuc
    Last Post: 01-14-2010, 06:16 PM
