586,121 active members*
3,440 visitors online*
IndustryArena Forum > CNC Electronics > SmoothStepper Motion Control > Issue noise motors on MB3-ESS card
    May 2011
    37
    hi... I have a issue for setup the motors stepper on MB3-ESS card.. I had wired 3 motors when I run the g-code file I feel that the signal output got to the motors, but them not move or move a very little step .. I'm confused about how to config fine match4 and this card.
    the motors are : 85BYGH450C-012B
    driver DM860A
    I have attached here a shoot pictures of mach4 and ESS plug-in and a movie for help better... I hope the video is clear...
ID:	436199Click image for larger version.
ID:	436195Click image for larger version.
    Nov 2013
    4376
    Re: Issue noise motors on MB3-ESS card
    none of the attachments are viewable.
    What evidence do you have that the signals got as far as the motors?
    What microstepping regime have you set your drivers for?
    What is your motor tuning (steps/unit)?
    What units (inches or mm)?
    Do your drivers have an enable signal and is that signal present?
    Craig
    May 2011
    37
    none of the attachments are viewable. ----> Click image for larger version.
    What evidence do you have that the signals got as far as the motors? -->> Can you explain better ?
    What microstepping regime have you set your drivers for? ---->> I not set it, because I not understand where set this parameters.
    What is your motor tuning (steps/unit)? ---->>You mean in the menù ESS pluggin set ? yes I set option Step/unit..
    What units (inches or mm)? ---> I have setting in MM
    Do your drivers have an enable signal and is that signal present? you mean the ENBL + and - signal on the therminals drivers ? I need of wire also them ?
    Craig
    Craig sorry if I not understand all your questions listed , If you have need of other info , please don't hesitate..
    Nov 2013
    4376
    This is what you posted.....what I want to know is how you know the signal got to the motors? That the motors are not going suggests to me that the
    signal DID NOT get to the motors.
    Just about all stepper drivers have micro stepping, it helps smooth the motion. Usually there are DIP switches on the board for setting the microstepping.
    Do you have a manual for the drivers? Have you bothered to do a Google search on microstepping?
    Motor tuning, including the steps per unit are in Machs Controll not the ESS plugin. How did you set the steps per unit if you don't know about microstepping?
    The drivers WILL require n Enable signal (ENBL+ and ENBL-).
    Craig
