587,149 active members*
5,296 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > Help me figure out this tool path
    Aug 2010
    599
    I am using a user defined woodruff key cutter that needs to cut an inner groove (like an o-ring groove). The problem is that the tool plunges and retracts through the top of the parts edge instead of the middle where it can clear. How do I change where the tool plunges and retracts to the middle of the diamond shaped toolpath below? By the way this is a 2.5 axis profiling MOP with the highlighted region set as bottom of cut geometry.
    Jan 2004
    3154
    DO NOT double post your questions
    www.integratedmechanical.ca
  1. No tool path?
    By spincaster in forum Rhinocam
    Last Post: 04-07-2010, 03:37 AM
  2. Simple tool move - can't figure it out.
    By HankMcSpank in forum Mastercam
    Last Post: 02-03-2010, 07:51 PM
  3. can't get the tool path right
    By msn_jrd in forum Mastercam
    Last Post: 07-21-2008, 04:43 PM
  4. need tool path
    By wcopley in forum BobCad-Cam
    Last Post: 06-19-2008, 11:13 PM
  5. Tool approach Tool Path
    By Kiwi in forum BobCad-Cam
    Last Post: 07-05-2007, 08:35 AM
