588,029 active members*
4,555 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Spindle motor replacement
Page 1 of 3 123
Results 1 to 20 of 52
    Sep 2017
    49
    My cnc spindle motor makes a blue light that i think are sparks when i am machining, should i replace the motor ? The motor that is on it is the original old motor.
    Fyi-My machine is a labvolt 5600.
    Sep 2017
    49
    Re: Spindle motor replacement
    i removed the spindle motor and when i ran it i saw a lot of sparks on the brushes, i would like to replace the motor with a brushless motor do you have any recommendations for what motor to use? what are the specifications for a motor that would work?
    According to their website, it's a 1HP motor? Without knowing the size of it, It's hard to say what will fit. Maybe an 800w spindle like this?
    https://www.ebay.com/itm/800W-220V-E...EAAOSw2s1UtyXj
    Sep 2017
    49
    the motor needs to be offset to the back because it is an r8 collet system
    Dec 2013
    5721
    Can you post a picture of the motor? Maybe the data plate. Any idea what the frame size is? According to the web site it's a 1 HP, ~3400 RPM motor. Pretty much sounds like a NEMA 56 frame. But could be metric or a special.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2017
    49
    I will post a picture of the motor tonight when I get home. I am not sure about the mounting holes, but i think making an adapter plate to have to motor attach shouldn't be to hard, I also have to figure out and source the pulley for the motor.
    Sep 2017
    49
    what i was originally thinking is that i would buy a motor and driver from a place like hobbyking and then build an adapter plate to mount it to the machine, i just don't know what motor and driver would work.
    Dec 2013
    5721
    You should concider buying a motor that is in the same RPM, torque range (or a bit more), and general style to maintain the performance characteristics of your machine. I don't think a RC model type BLDC motor would be what you want, they are normally high RPM motors. Based on the published specs, a 1KW servo motor would be in the range of what you are looking for. Or use a inverter duty motor and a sensorless vector VFD.
    Jim Dawson
    Sandy, Oregon, USA
    24220
    There are also Fanuc yellow cap DC servo's you could utilize as a spindle.
    If going that route it will pay to check out the status of the brushes and if it need any internal cleaning.
    In good shape, these are nice motors.
    Also Treadmill DC motors
    What is the nature of the present drive?
    Al.
    Albert E.
    Sep 2017
    49
    What do you mean the nature of my present drive? And i would like a relatively inexpensive spindle solution.
    24220
    How is the present drive controlled? What kind of signal? 0-10v etc. What is the voltage of the DC motor?
    If you can keep the present drive, the ex- T.M. motor might be a low $$ answer.
    Al.
    Albert E.
    Sep 2017
    49
    I have a motor controller that i controller with a 5 k ohm potentiometer
    Sep 2017
    49
    And the motor that was on there is 90v dc.
    24220
    What make controller and voltage of motor?
    90v so a T.M. motor should fit the bill.
    Al.
    Albert E.
    Sep 2017
    49
    Those are the pictures of the bad spindle motor.
    Mar 2017
    926
    Automation technologies sells two milling spindle motors - a 1kw and a 2.2kw which come with a controller / speed control.
    Tormach sells the motors separately for both their 770 (1hp) and the 1100 (1.5hp). They also sell them as complete heads.
    little machine shop sells a variety of small milling motors as well as complete mini milling heads
    Sep 2017
    49
    I removed the spindle
    One problem that might happen with a new spindle and vfd is that the normal spindle is 8 inchs from the z axis, does anyone know a good way to offset it?
    24220
    The DC T.M. motors I have used such as the Johnson, are 4.2" in O.A. dia.
    Al.
    Albert E.
    Dec 2013
    5721
    The more I read through this thread the more confused I get, but I'm old so maybe I just confuse easily.
    I understand you want to replace your spindle motor. Are you wanting to speed up the spindle also? The spindle specs from the website indicated that the original motor is a ~3400 RPM motor. Are you now suggesting that you want to go with a router spindle that will turn in the 24,000 RPM range? That would give you a minimum speed of about 6000 RPM.
    As far as spacing a router spindle out 8 inches, a large aluminum block would be my choice.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2017
    49
    I am trying to figure out the best way to get my mill up and running again, i am considering all of the ways of doing so then i will do what ever is best. Right know i think the best way is to just figure out what replacement brushed dc motor would work for the rpm and mounting.
Page 1 of 3 123
  1. Replacement spindle motor driver
    By efret in forum Spindles / VFD
    Last Post: 10-07-2016, 05:40 AM
  2. Replies: 1
    Last Post: 03-06-2013, 05:19 AM
  3. NM-200 Spindle Motor Replacement Upgrade Kit
    By Novakon in forum Novakon
    Last Post: 05-10-2012, 05:55 PM
  4. server motor for x3 spindle replacement
    By dwessels in forum Benchtop Machines
    Last Post: 04-08-2009, 01:45 AM
  5. Spindle Motor replacement?
    By Trapper14 in forum Mini Lathe
    Last Post: 03-10-2006, 11:48 PM
