The factory says rapids of 30ipm, but that is the extreme with the stock control and steppers. In practice you rarely exceed 10-15 ipm when milling, depending on depth of cut, number of flutes, diameter of cutter, spindle speed, material, etc.
The spindle speed is max 10k rpm.
I have had some customers say they got higher rapid speeds (and cutting speeds) with aftermarket controls and steppers.
Originally Posted by
Smertrios
How fast are the TAIG mills or rather how fast can they be?
Nick Carter
Largest resource on the web about Taig lathes and mills
www.cartertools.com
