587,106 active members*
3,790 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Jan 2007
    172
    memory card error "1010"???
    everything going fine, running dnc from cf card. Reposted a program, reinserted card in remote mode, got this alarm. (OIMC control). Tried another card that was fine, same alarm. Restarted machine, reformatted card at PC, same alarm. I cant find "1010" alarm in the book, so I dont really know where to start. any help would be super!
    Jan 2008
    30
    How did you format the card?
    It is the poor craftsman that blames the tool
    Mar 2007
    122
    1010 ALARM
    This is just an alarm that tells you that you haven't put the card in properly. Normally you can pull the card out, press the reset button and reinsert the card and everything will be fine. But since you said you tried another card that was fine, then the next thing to look at would be the control card reader. It might be wrecked. Check the pins and make sure they are clean and not bent.
    Apr 2007
    148
    Quote Originally Posted by CAD/CAM Man View Post
    CAD/CAM Man might be onto to something, format the card at the controller, fanucs can get picky about how the formating is done on the card. Also try shutting everything down and then restart and see if that works.
    Jan 2006
    1010 Error
    I just purchased cards made by kingston and they all give that same error, while our sandisk cards don't cause problems. Maybe manufacturer has something to do with it?
    Dec 2009
    14
    please format the card in FAT mode, copy again the programs u need and insert into the machine. If ur computer is free of virus everything goes well as per my experience.
    Mar 2007
    122
    I found that the cards made by Kingston on work if they are 2GB or less. The original Sandisk will work up to 4GB but I found Transcend Industrial to be one of the best cards to get.
    May 2015
    12
    Quote Originally Posted by spock View Post
    Fanuc Memory Card Error 1010 Error Codes are caused in one way or another by misconfigured system files in your windows operating system.
    If you have Fanuc Memory Card Error 1010 errors then we strongly recommend that you Download (Fanuc Memory Card Error 1010) Repair Tool.
    This article contains information that shows you how to fix Fanuc Memory Card Error 1010 both (manually) and (automatically) , In addition, this article will help you troubleshoot some common error messages related to Fanuc Memory Card Error 1010 error code that you may receive.
    Note: This article was updated on 2016-07-11 and previously published under WIKI_Q210794
    Contents
    1. What is Fanuc Memory Card Error 1010 error?
    2. What causes Fanuc Memory Card Error 1010 error?
    3. How to easily fix Fanuc Memory Card Error 1010 errors
    The Fanuc Memory Card Error 1010 error is the Hexadecimal format of the error caused. This is common error code format used by windows and other windows compatible software and driver vendors.
    This code is used by the vendor to identify the error caused. This Fanuc Memory Card Error 1010 error code has a numeric error number and a technical description. In some cases the error may have more parameters in Fanuc Memory Card Error 1010 format .This additional hexadecimal code are the address of the memory locations where the instruction(s) was loaded at the time of the error.
    The Fanuc Memory Card Error 1010 error may be caused by windows system files damage. The corrupted system files entries can be a real threat to the well being of your computer.
    There can be many events which may have resulted in the system files errors. An incomplete installation, an incomplete uninstall, improper deletion of applications or hardware. It can also be caused if your computer is recovered from a virus or adware/spyware attack or by an improper shutdown of the computer. All the above actives may result in the deletion or corruption of the entries in the windows system files. This corrupted system file will lead to the missing and wrongly linked information and files needed for the proper working of the application.
    How to easily fix Fanuc Memory Card Error 1010 error?
    There are two (2) ways to fix Fanuc Memory Card Error 1010 Error:
    Advanced Computer User Solution (manual update):
    1) Start your computer and log on as an administrator.
    2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
    3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
    4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
    5) Click Next on the confirmation window.
    6) Restarts the computer when the restoration is finished.
    Novice Computer User Solution (completely automated):
    1) Download (Fanuc Memory Card Error 1010) repair utility.
    2) Install program and click Scan button.
    3) Click the Fix Errors button when scan is completed.
    4) Restart your computer.
    How does it work?
    This tool will scan and diagnose, then repairs, your PC with patent pending technology that fix your windows operating system registry structure.
    basic features: (repairs system freezing and rebooting issues , start-up customization , browser helper object management , program removal management , live updates , windows structure repair.)
    Oct 2012
    40
    Hi
    Still you are using card for programs transfer,
    I have a unit where you can transfer the programs
    Through USB pen drive.
    Aug 2005
    82
    Re: memory card error "1010"???
    Hi
    Pls send more detail about your USB pen
    I have problem on 1010 error now
    Aug 2005
    82
    Hello spock
    Recently I have problem card Error 1010
    Fanuc OI MB
    So How you fix it.
    If you can share tp me will be appreciated.
    Charlie
    May 2016
    526
    Try formatting the card on the machine
    Aug 2005
    82
    Hi
    I have format with machine.
    It complete.
    Then Restart.
    Card error still there.
    If I remove card and try to read data from Card.
    Machine say. insert card."
    Put card in.
    Memory card Error:
    Any point for looking?
    Feb 2006
    1792
    Try a low-memory card.
    May 2016
    526
    do you have a 512mb card or an sram ?
    Aug 2005
    82
    Hi
    I have 64 M and 2GB
    Few days ago both work fine.
    May 2016
    526
    Probably your slot then they are about £40 from fanuc
    Feb 2006
    1792
    Because of this reason only, some people use extension cord with the card, rather than directly inserting it in the machine.
    Aug 2005
    82
    You mean adapter for CF card? ( I have 2 adapter That get same Error )
    My Machine Card slot is direct to Main Box of controller.
    Easy to replace?
    May 2016
    526
    yes
Page 1 of 2 12
  1. Patch files for "freeze" problem of 6525 Leetro card.
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-23-2021, 05:36 AM
  2. "master encoder state error" AB ultra100 error message
    By ShapeShaver in forum Servo Motors / Drives
    Last Post: 07-31-2013, 04:09 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. "Memory Card Error 121"
    By pdubya_CNC in forum Commercial CNC Wood Routers
    Last Post: 04-21-2011, 09:58 AM
  5. Mazak T-2 "20 NMI Emergency Stop" Error"
    By Jeff_Y in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-11-2011, 05:35 PM
