588,400 active members*
4,721 visitors online*
    Jan 2011
    30
    Capability question
    How good is the 770, at doing very small moves on 3D parts?
    Software to generate the tool paths not being any issue, rather how well the Mach controller moves the steppers in very small steps.
    I need a machine that can make a mold for carbon fiber composite parts, finish straight off the machine is a big factor.
    The best example of what I would like to be able to do with this machine is molds like this link.
    http://web.me.com/walterberger/Merli...s/DSC04425.jpg
    I ask because I have some doubts due to a recent post.
    I considered outsourcing the work, but found it extremely expensive.
    Oct 2007
    269
    I have outsourced parts on a $60,000 machine which didn't have the finish you are looking for right off the machine, and that wasn't even 3D. May be why the cost is so expensive.
    Jim
    Jan 2012
    789
    It is exceedingly hard for any tool to create a perfect finish. Most cutting operations will leave a tool mark of some kind. That is why it is often better to do some hand finishing afterwords.
    Also, creating the jig to hold that part will be a challenge.
    Aug 2009
    986
    The mold in the picture has been finished by hand, probably with sandpaper.
    There's nothing wrong with doing it that way. I've done 3D surfaces on my 1100 that sanded smooth with just a couple of minutes of work. The 770 should be just as good, if not better.
    Frederic
  1. Newbie asks micro/mini mill capability question
    By Molybdomancy in forum Taig Mills / Lathes
    Last Post: 02-11-2011, 04:02 AM
  2. CAD Capability
    By Chipload in forum GibbsCAM
    Last Post: 09-26-2009, 01:19 PM
  3. Y-axis capability
    By cutting edge in forum Haas Lathes
    Last Post: 09-25-2008, 03:00 PM
  4. Best way to get Al engraving capability to VMC?
    By AKFALAR in forum Uncategorised MetalWorking Machines
    Last Post: 06-14-2008, 04:13 AM
  5. Capability
    By jhwatts in forum Xylotex
    Last Post: 01-16-2006, 04:37 PM
