588,531 active members*
8,409 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > 6061 Aluminium questions
    Sep 2005
    84
    I looking at some large numbers starting now in 6061. I have a few pockets in a part that are -.260" deep and -.457" deep. I'm doing it with a 1/4" HSS 3 flute cutter now and on the -.260" dp pocket, I'm doing it in 2 passes, 4 on the other. Now my question is:
    1. Would the "principals" of high speed machining be better to make say 7 passes on the -.260 dp pocket at say 10X the feed? Or what would you recommend?
    Pocket is roughly 1" square and the other part is say 1" X 2" and another 1" square. Rads. NEED to be .128 MAX. Can ramp or plunge in.
    Thanks, John:rainfro:
    Jul 2005
    12177
    You missed saying what your speed and feed will be so of course it is not possible to know how fast 10x the feed is.
    Doing these pockets I would look at using a Carbide 3/8" dia. 45 degree helix two flute, GAR 242, at 10,000 rpm and a feed of at least 100 ipm ramping down to full depth on the shallow pocket and doing the deeper in two ramps. Then switch to the 1/4" for a finish pass. Flood coolant would be needed to get good chip evacuation.
    Sep 2005
    84
    Geof, thank you. RPM limit is ONLY 6000. So I run it to 5950 RPM and 42 IPM with 3 flute 1/4" 3 flute HSS cutter. Thanks and will look into that as well. John
  1. Best milling finish on 6061
    By SRT Mike in forum MetalWork Discussion
    Last Post: 03-31-2011, 03:35 PM
  2. plating 6061
    By dafowfidy in forum MetalWork Discussion
    Last Post: 01-29-2007, 03:39 PM
  3. End-Mill bit 6061
    By Ed Williams in forum MetalWork Discussion
    Last Post: 05-31-2006, 05:18 PM
  4. Parting 6061
    By ozzie34231 in forum MetalWork Discussion
    Last Post: 06-27-2005, 06:04 PM
